How to Disable Incoming caller full photo display?
Hi Bro,
Is there any ways to disable full contact picture during incoming / outgoing calls?
I need to display it left side of the iphone’s corner.
Hello bro, you can reverse the steps suggested in our video. If a contact picture is not full resolution as suggested, then it will show small round in the corner. if you upload high quality photo for a contact, then it automatically converts to full screen incoming caller id background photo. we cannot change that manually bro.
Could you please share the video link?
Here bro,
if you remove the high resolution photo and set square or 4:3 photo as contact picture, then it will not work as full incoming caller screen photo.
