Robin bro in 18.5 my iphone is overheating I didn’t use phone but heating they want to fix it in iOS 18.5.1 any tips there
Hi bro, is it iPhone 15 plus? can you share last 24 hours battery page screenshot here?
Bro in my WhatsApp lists option not showing from 2 years
According to your usage the battery graph looks good bro. 20% around varumbothu charge pannunga. that will help. Heating during gaming or video streaming in mobile data is totally normal. it automatically reduces and manages the temperature.
its whatsapp specific feature bro. some features are delayed for some users and we have to reach out to whatsapp support through whatsapp settings - help and feedback section.
try app offloading method once and see if that helps or not bro.
Its doesn’t work bro Iam waiting 2 years but not comes
In that case completely reinstalling whatsapp is required bro. temporarily get icloud storage for one month. then upload your whatsapp backup to icloud within whatsapp settings. then delete whatsapp and reinstall whatsapp and restore the backup. this is one time step. so dont skip the backup restore. we cannot restore the backup after we skipped it right after reinstalling.
If you dont have important chats to backup, then you can reinstall whatsapp and check once bro.
Bro how to off beta updates option
within settings - general - software update - beta updates toggle has to be OFF bro. so future iOS beta updates wont come to you. only stable when released you will receive.
Bro don’t want see beta option in software update
that option cannot be removed bro. its set by default. we can avoid enabling any beta updates. its optional and select beta updates to off and then you will receive only stable updates bro.
