Bro i have download the ios 18 dp update there so many bugs i cant some apps crashing black screen i want to delete ios 18 dp update can u help
Hi bro, do try the follow steps and you can downgrade to iOS 17. will bring one video next week, but the steps are going to be same.
Bro how to download iOS 17.6 I am in iOS 18 beta 5
I’m iPhone 15 plus user I want upgrade to iPhone 16
Hi bro, sadly the downgrade without data loss method explained in above video wont be working right now. due to bugs in iOS 18 this feature is still not working. we have to wait for 1 or 2 more betas to see the feature working again.
For now we have to completely erase and do iOS Restore.
If we have important data then we have to backup the data to icloud and restore it after iOS 17 installed.
Bro how to downgrade iOS 18 dp 8 to iOS 17.6.1
There so many bugs iOS 18 bro and sound was low in speaker. Headphone
Right now downgrade without data loss is not possible bro. we have to backup data manually to icloud drive or local computer. then clean install iOS 17.6.1 latest stable version. then we can move the data bro.
Try force restart once bro. sometime it could be software related issue. in 2 weeks we will see official release of iOS 18.
- Press and Release Volume UP Button once.
- Press and Release Volume Down Button Once.
- Press and Hold Power Button (Side button) till you see Apple Logo and release your finger.
That could help seeing improvement.
When will come iOS 18.1 beta 6 bro there so many bugs in dp 5 so I waiting to the update
expecting update this week bro.
IOS 18.1 call recording feature set record manually when automatic call recording will come bro.
In my iPhone 15 plus after the battery drain and more laggy feel bro
its more like a transcription feature bro. so it wont happen automatically to avoid occupying more storage. your iPhone model and current battery health percentage bro?
Robin bro I can’t able change the country region its not showing bro can u help me
What error you are getting while changing country region bro? are you trying to change it for your apple id? any active subscriptions there like apple music, icloud or third party apps?
Bro the option country region is not showing I don’t having active plans subscription please help me bro
Do check within settings - screen time - content and restrictions feature is OFF bro. check country region settings again and if still problem means, let me know.
My device 15 plus bro Iam charging for 3 times per day sometimes 2 times my battery health is 87
I will share the battery usage photo
Bro Iam apple care plus
This year I will expire…
Can battery for freee
Hi bro, from the above graph it seems your usage is quite high with video streaming mostly. in such cases battery drain is normal especially in mobile data. if its wifi depending on the video quality we stream battery drain difference will be there.
We can claim applecare+ if the battery health reaches 80% level within warranty period. with That 7% will take 8 to 9 months atleast to reduce it to 80%.
how many months more warranty you have left?
Bro apple care was expiring sep 2025 what can do
5 months more there bro. use the device and see if you are able to reach that limit. else you can check one month before at nearest apple service center what else can be done too. normally if the phone is damaged then we can claim the entire iPhone but claim fee is 8900 approximately for such claim.
For battery it will be 2500 only. I think they can make exception and replace battery if its near to 80%. so dont worry. continue using it the way you want and we can check one month before warranty ends.
