How to enable 5g in 14+… Jio what is 5g standalone?
5g auto or 5g on. What can we use?
If standalone use any problem I’ll come?
Do update to latest iOS 16.4 version bro. also kindly check following episode recently published. explained the options.
Without update!! We can’t use 5g without standalone option ah bro?
in iOS 16.4 update apple removed that option for networks using 4G Core bro. if the network we use starts using full 5G Core, that will enable 5G Standalone toggle.
