How to share internet via usb-c to Lightning cable
Hi Bro,
Iphone la erundhu usb-c to Lightning cable vachu internet tethering panradhu yeppadi?
I am using windows laptop, in that thunder bolt usb-c port available.
Hello bro, I havent personally checked yet, but currently upto Windows 10 version USB C to Lightning cable mostly allows charging only. Your Windows OS version?
Okay,bro. But can you please try and let me know.
I am using windows 10 21H2 version bro. My laptop doesn’t have Ethernet port, so i am using usb-c to Ethernet adapter, that’s working fine.
But, if i do tethering , no luck.
with laptops most people using wifi hotspot bro. thats why this problem must have not noticed by many. one of our mod recently said that they are unable to use iTunes whenw connected with USB C cable. let me check with his machine.
Okay, bro.
Hi Bro,
Any update?
Because I tried with Android phone (usb c to usb c). It’s working fine.
But, on iphone ( lightning to USB c), unable to share the internet. ( Using apple original cable)
The challenge i have in wifi hotspot is that if i keep my laptop idle for 3 minutes the hotspot disconnect automatically. So looking for usb c tethering bro.
hi bro, for wifi hotspot not working on iPhone, you can try this work around.
this will fix and provide stable hotspot connection with your windows laptop. my friend also not able to get this work with his windows pc, but works fine with his mac computer. so strange, some additional driver support seems to be required to enable tethering feature with the USB C to Lightning cable.
let me know if above suggested wifi hotspot works.
Actually I have tried it and it was working
1.connect the usb c to the lap and lighting to the iPhone
2.On iPhone settings->Personal Hotspot->Turn On
Now on checking the connection on the laptop it shows the ethernet was connected
