Hi bro i want to type i sqaure 2,how to do in mac when i use option key and type i™ it shows like this
Hello bro, Do try the following steps,
Step 1: Open the character viewer by pressing the Globe key in the keyboard or “fn” key, the first key at the bottom left corner of your mac keyboard.
Step 2: Then search for “superscript.”
Step 3: You can select any number, which will be displayed as squared 2 on Mac.
Try and let me know if that helps.
hi bro, thanks, it’s working, For every time I have to follow these steps or any other shortcuts available
I dont think its possible to have another shortcut bro. we have to use it from character viewer if the app we use dont have that squared 2 option. like in MS Office they have separate button available in the toolbar.
ok bro thanks
