Sir, we want to upgrade our iMac 2019 model Ram from 8gb to 32 gb kindly guide us which brand to buy and where to buy thank you.
hi bro, I have used Corsair vengeance RAM before when I upgraded my 27" iMac 2019 model.
You may consider, the same brand as my iMac is still running well and friend is using it.
imac 2019 model supports 2666 Mhz frequency RAMs. so this should be good choice. Do record video while unboxing if you are ordering it online. You can check with any local computer shops once to compare the pricing and decide where to order bro.
