How to use iCloud Storage as separate and not to use iPhone Storage?
I am new to iphone . I purchased Icloud storage of 50GB for Rs75
I thought it would be separate storage in such a way that i can move some of the files to that and clean my internal memory.
But actually it not happened!!
The icloud storage still uses the phone memory, i can see them in setting and storage why so?
Please explain panuage konjam ?
iCloud Storage helps us to backup photos app content, apps data and icloud drive data bro. It is not like third party cloud storage where we can upload all the data and remove data from local storage. it works differently.
Purpose of iCloud is to sync and share the data with other devices.
In terms of photos app contents like photos and videos, it takes backup and then we can select optimise storage option to store only smaller compressed files in our storage. so our local iPhone disk storage will be free to certain level.
Using Files app, we can use iCloud Drive to manually upload files and sync the same files to our local storage or not, based on our selection.
Do refer this episode and you may get some idea bro,
Let me know if you have any further questions.
