How to use same apple id for two iPhones?
How to used two phones (6s&14pro) same Apple ID
hi bro, you can login with same apple id on two iPhones. are you facing any problem with signing in?
I don’t try
Now u answer after sign in
Storage how to share
All apps no problem
Example what’s app , imo , Botim how to use two phones
one apple id multiple iPhone la login pannalaamnga. no problem. appstore la poyitu same apps install pannunga. you can use it bro.
