I am new to iPad, How to Install Fonts?
I am new to iPad 13, if any instructions or tips before using and also how to install Tamil fonts in ipad
Hi bro, congrats on your new iPad. in iPadOS we cannot install fonts directly. we can use the tamil fonts or other fonts only if the app allows it. for example, if you are using adobe photoshop or any designer apps, then within the app we can install fonts. the app has settings to install fonts within the app and not system wide fonts installation possible.
You can try with this third party keyboard.
to use most of the tamil fonts available and compatible bro.
Thanks bro for your immediate response and reply
