Iphone 15 plus …ios 18.1…my phone idle time battery drain issue
Kindly share last 24 hours battery page screenshot with apps section visible bro. scroll down a little bit in battery graph page in one photo and show both last 24 hours + 3 or 4 apps in top of the graph bro.
Hi… bro actually iphone 15plus vaagi 7 month aachy…bro 28 charge cycle count…ios 18.2 current version bro…
Ippo konja days ah…idle time la adhiga battery drain aagudhu …bro 1st naa .notice pannum podhu… night 80% la charge disconnect panne…bro… morning…72% dhaa irunchu …so na YouTube la search panne…bro…idha pathe…appodha unga battery drain videos paathu… settings la change panen …then…idle time la…16% drop aairuchu…![]()
Then…unga app install pannitu…idle battery drain pathi check pannum podhu …neega maximum ellarkum… network search pannitu irukura naala… maximum…idle time la… battery drain aagum nu…sonniga bro…
So Today naa… morning 08.00Am… 80% charge disconnect pannitu…at the same time data also disconnect panniten…ippo time 08.00Pm varaikum…80% charge la… maintain aagudhu…bro…
Naa today nyt data on pannitu … tomorrow morning eulo idle time…la battery drain aairunuku … screenshot send pandren …bro ![]()
Good to know bro. each day network and background processing difference irukumnga. namma device ellame oru mini computers mathiri. overnight 10% varaikum some day aagum, background updates, location services or network search mathiri reasons naala.
most days la antha mathiri aagathunga. but intha difference irukum and that is normal.
charging practice follow pannitu use pannunga. eppo 20% nearer varutho unga usage poruthu charging pannikonga. it will be good.
Thank…you bro ![]()
Bro…data on la irundha… network searching la… battery consume pandradhunaala…naa data off panniten… yesterday la. Irundhu…romba battery drain bro…idle time la…mela picture share paniruken bro ![]()
From the graph, neenga SIM Card irukara varaikum less consumption aagite thaan irukumnga. phone normal la use pannipaarunga. 1 day backup varum bro. sim card insert agirukumbothu.
Mobile Data OFF pannaalum SIM card network signal search and background system services kaaga romba kammiya consume pannite thaan irukum bro.
From the graph you can see 40% around la irunthe 24 hours ku mela ungaluku charge hold agiruku.
entha oru electronic device um laptop, tablet, smartphone ON la irunthuchuna few percentage consume pannumnga. OFF la irunthaalum lithium battery la irunthu slow va daily reduce agite irukum bro.
So unga usage ku 1 day varuthanu paarunga. idle time overnight evlo percentage drain aguthunu paarunga. within 10% reduce normal. athuku mela iruntha namma enna reason nu check pannalaamnga.
Ok…bro I will check…phone vaaguna pudhusula…data on la irukum podhu…kuda indha maari…drain aagala…bro… ippo 1 month ah…dha bro…indha problem… actually…1 charge 80% la 5 to 6 days…aagum bro 30% to 20% reach panna…indha 1 time 3 days la 80% to 20% vandhuruchu…
Today night I will check bro…eulo percentage drain aagudhunu check pandren bro…
namma usage ku thaguntha mathiri optimise aagumnga. sure morning around 7AM check pannitu sollunga. also ippo night above 50% charge irukura mathiri pathukonga.
Night 80% charge irunchu bro… morning 7clock 72% irunchu bro…
IOS - 18.2 eppo bro varum…innum receive aagala
8% reduce is totally normal. dont worry. 18.2 update intha week expected bro. today morning namma video la sollirukara mathiri charge 80% or 100% pannitu use panna aarambinga.
20% varumbothu screenshot share pannunga.
Ok…bro try panni paakren…next 20% varum podhu screenshot share pandren bro …
