If I update 17.4.1 batteries will drain?
Hai bro na iphone 15 use panren. Ippa intha 17.4.1 update panna battery drain issue varumaa. Apram camera use pannum pothu mobile heat aguthu
hi bro, current iOS version 17 la irukeenga na update pannalaamnga. most users reported same performance as 17.4. which version you are currently using bro? also this 17.4.1 is minor update as explained in our recent episode.
Na 17.4.1 la than use panre bro but camera vedio use pannum bothu warm aguthu
That is normal bro. in normal temperature conditions we see warm temperature. with current summer season and camera app shoot normally uses more hardware resources for processing. takes time for temperature reduce and air circulation to reduce the temperature bit faster.
