Image playground not showing
Hi bro!
iOS 18.2 update pani Region and language US ku change pannium image playground app show aaga matuthu bro enna pandrathu?
hello bro, currently india la irukeengala or abroad?
India bro
Settings - general - language and region - united states la set agirukungala?
Also Settings - Apple Intelligence and SIRI - Language - United States set agirukungala?
Yes bro both are set to US
Some setting is preventing the download to happen bro. Is the device provided by company or any profiles installed to use specific apps? do check once in settings - general - VPN & Device management. do you see any profiles there?
No my own device bro. Ila bro VPN profile onnum show aagala.
Hotspot la connect pannirukeengala or actual wifi router?
Actual wifi router than bro
Settings page screenshot onnu share pannunga. also SIRI Settings screenshot bro.
Go to settings - screentime - content and restrictions. turn it off then restart iPhone once. Then check apple intelligence is working normally or not bro.
Bro apple intelligence work aaguthu but playground app than still varala.
Neenga sonna mathri content and restrictions turn off panitu restart panni pathuten still playground app not showing.
Appstore la image playground app open aaguthungala? already install agalaina install pannitu check pannunga from the following link.
Not available in your region nu varthu bro.
Settings - General - Language and Region page screenshot share pannunga bro.
everything correctly configured bro. go to app library and search once for image playground. see if it shows up or not.
this is so unique, so far no other users experienced similar issue bro.
Some specific setting is causing the issue preventing you from accessing image playground. Once check settings - general - software update and see if any pending update bro. expecting 18.2.1 with bug fixes very soon. so if there is no pending update for you, then do update right away too bro.
we have to wait in this case to figure out after next update.
Okay bro thank you
