Instagram login problem, loading blank page
Hi sir,
Recently i have reinstalled the Instagram application because of more amount of data.
But after installing again it not proceeding the login blank page. It is like a black screen.
Please kindly help with is issue sir!!?
hello bro, this could be temporary problem. can you try accessing the same via mobile data? try restarting the phone once and then use mobile data and open instagram.
No sir
I have also restored my iphone after that also i am facing that issue sir
My contact number *********
Please call me sir
Please dont mind bro. Phone support is not possible for me. due to day time work and in between I answer the questions. Keeping all discussions public to help people in future coming with same problem to find solution. I hope you understand. :heart:
For privacy reasons I also removed your phone number from above post.
Does the problem happening only with Instagram app? can you open Instagram website in safari browser and login with your account details and check?
Yes sir i can access for web like safari.
Only with instagram i am facing this issue
do perform “Settings - general - reset - reset network settings” once bro. then check if instagram works normally or not.
Bro i am also currently facing this issue in my iPhone 15 plus. Tried all the solutions from youtube but nothing worked, can You help bro
Have you tried reinstalling instagram app bro? also in safari when you open instagram app is it loading and login working properly? only in app you are experiencing this issue?
Yes bro tried reinstalling several times but that didn’t work. I can login from all other devices and browsers only problem while logging in through my iPhone
In such case its recommended to do All settings reset once and check again bro. if still problem continues, then do iOS Restore after taking backup then restore backup and then install instagram app and check bro. sometime the issue could be deeper and cant be fixed with just reinstallation of App.
Thank u bro will try that
