IOS 16.2 update pannina pirahu call pesum pothu loud speaker auto va activate aahi 2-3s la again deactivate aahuthu.
Antha time pesurathu ketkuthu illa😢
Ithukku eathum solution irukka
Hi bro, it could be temporary bug. Once restart your iphone and check bro. If problem repeats let me know.
Yes bro
It’s repeating again
This problem came after IOS update 16.2
Whats app or other application calls are no issue
Normal call only showing this issue
This problem happened few versions before bro. I checked in both iphones and the problem is not happening. Fixed actually.
Do try settings - general - reset - reset all settings once. It may help clearing out software related issues bro.
Ok bro i will try to reset settings
Hi Bro,
Enakum same issue… still your facing this issue?
Have you updated to latest iOS 17 or using iOS 16.6.1 bro?
iOS 16.6 bro
