iOS 16.5 Battery back up for iPhone 14 plus
Bro can you please share your battery backup for your 14plus…
Because in my 14plus also it got reduced to 1day with average use… is there any steps to fix this?
Hi bro, after iOS 16.5 I too experienced battery drain. then performed all settings reset and adjusted location and privacy settings as suggested in our video. Now its much better. for normal usage getting 1.5 days and for traveling and heavy usage it drains and gives 1 day backup.
Do try and let me know after 3 days usage bro.
Bro
Screen off epd calculate aaguthu and epd screen off set panurathu .
Soluga ?
battery graph page la activity section la light blue color irukarathu screen off time la apps use pannuna resource detail bro. dark blue color screen ON time la irukarathunga.
Enaku dark blue matum dha bro iruku
Okay :+1:t2:
