Hello Brother @iRobinPro settings ulladi Face id & Passcode optionah kaanom. How to fix it??
Do restart iPhone once as basic troubleshooting step and check bro. Else follow these steps bro if face id disabled,
LockScreenla correctah work aaguthuтАж but settings ulladi antha optionae kaanom bro kindly do help @iRobinPro bro
oh, then its not defect bro. I think some screen time settings enabled to hide this option. go to screen time and turn it off completely. then check if face id and passcode option is showing or not.
Hi bro im alos facing the same issue face id nd passcode is not showing bro
Do try above screentime option bro. turn it off completely and check. let me know if that works out.
Sure bro I will try to do it nd let u know broтАж!
Yes broтАж!! ItтАЩs working now fine if I turned off the Face ID option is showing if I turned on option is not showing bro Thnk bro for suggestionтАж.!!!
