iOS 17.1.1 battery drains faster in iPhone 12 mini
Hi bro
I am using IPhone 12 mini, I have noticed that after the 17.1.1 iOS update, my battery got drained faster than before and also noticed heating issue during charging. Is that because of new update?
hi bro, so far it has positive reviews when it comes to battery performance. whats current battery health percentage? if there is any issue with the update we downloaded then we may see such problems too if battery health is in good condition.
Bro.
I have read somewhere after the updating the iOS it is better to restart. So I tried then it came back to normal. Btw my battery health percentage is 86%. Can you suggest which iPhone model would be better for upgrade?
good to know you are seeing improvements bro. when you think its time to upgrade, if you prefer compact holding then you may check with iPhone 15 model bro. depending on your budget preference. It has the latest hardware packed good to use for next few years without feeling it outdated.
Otherwise, you may consider iPhone 14 model based on offers price.
