Bro I am using iPhone 13 it is advisable to upgrade iOS 17.3.1 because few people reviewed that after update there is a network connectivity update and battery draining
List item
problem in iOS 17.3.0. After getting ios17.3.1 few issues fixed. Now I am using iOS 17.2.1 update on iPhone 13. So request you guide me it is advisable to update from iOS 17.2.1 to iOS 17.3.1
Hello bro, the green screen problem is so random. we cannot be sure whether it will happen with specific version update. make sure to backup important data always. Only then you can proceed with the update.
Each iOS version does comes with plenty of bug fixes. It will help with overall phone stability.
But incase of any such green screen issue in iPhone 13 models we have to check with apple service center. they will replace it for free bro. even if the device is out of warranty, we will pay 2000Rs approxiamtely to get it replaced.
