Bro 17.4.1 la battery drain avara Mari iruku ,yesterday install panen bro in my iphone 15 ?
Kindly share last 24 hours battery page screenshot bro.
Bro epdi bro share pana uploading apram error varuthu?
I have increased the file upload size bro. try uploading same screenshot again now.
Your overall usage is less bro. from the graph we can see, yesterday 6PM till morning 5AM, usage is stable and didnt reduce much. just background processing, network usage, notifications consumed some percentage. after that couple of hours usage along with charging reduce is minimum.
Overall its good bro. dont worry. just continue using the phone normally as you want. Charge it when it reaches 20%. you can charge it upto 80 or 90 or 100%. its not a problem. continue using it till it reaches 20% bro.
it will be maintained.
Thanks robin bro
Ena model bro?
