IOS 17.4.1 update panne apram iPhone 15 Pro Max heating issue and battery drain feel aavra maayi iki. Graph poduren check panni sollunge please???
hi bro, the graph looks very stable. you have charged around 50% upto 100% and started using it. do one thing. dont charge in between tomorrow morning. use it till it reaches 20% and share the same screenshot taken once it reaches 20%.
That will help to figure out fast battery drain problem is there or not. Kindly dont crop the screenshot, do share full page screenshot with apps section visible tomorrow when it reaches 20%.
Hi Bro, New 15 PM phone buy panni 1 week aavuthu 17.4 la thaan irunthichi but unga video follow up panni thaa 17.4.1 update pannen. But ellarum solrange so many bugs iriki ennu athenala enaku battery drain aavura maayi feel ah irunthichi. Nene sonne maayi use panni 24 hours graph poduren check panni nalla suggest solluge bro sometime phone a resell panre idea also vanthuchi
. Thanks! Iām from Sri Lanka
Good bro. oru sila users ku issues varumbothu namma video la sollirukara troubleshooting steps fix panna help pannumnga. but unga phone perfect a iruku. dont worry. unga battery graph normal la thaan irukunga bro. idle time la reduce athigama illa and use pannurapo gradual reduce irukunga. so same charging practice follow pannikonga.
and heavy usage some days la iruku appadina appo mattum in between la charge pannunga otherwise 20% varumbothu charge pannunga. all is well.
Thank you for your response! ![]()
