Na iPhone 13 Use Panren bro ippa ios 17.3.1 la Run Aguthu, ios 17.4 Update Pannalama ; Bugs & Battery Drain issue irukkuma bro ?
if current iOS version is good for you, wait for 4 to 5 days bro. we can update after hearing user feedback. that could help.
Am using iPhone 14 pro after ios 17.4 update my battery health was dropped 1% now in 99% and facing battery drain
Am using iphone 15 plus battery health 100 ,53 cycles am facing while charging phone is heating I don’t know what to do
When phone purchased bro? month and year of purchase?
during fast charging heating is normal bro. avoid using the device while charging, disconnect and use it. also current summer season plays important role. where room temperature is quite high and all electronics appliances get heat easily. during fast charging especially.
it automatically cools down. dont worry about it. just disconnect and use it whenever you need to use bro. it will be alright.
Dec312023
Bro charge la irunthu disconnect panitu switch off panitu on pana charge point increase agiruku bro ithu ena problem I don’t know what’s the issue and charging percentage from which percentage to which percentage maintain I don’t know really give some ideas bro
Restart appo software level measurement pannurathula mistake varumnga. but within few seconds or in few mins as we use, auto adjust agidum bro. not to worry.
simply follow the practice suggested in our channel bro. dont worry too much about battery health. simple charge it whenever you reach 20% around. that is enough.
It will be maintained over period of usage. 2.5 years average time to reach 80% battery health, so enjoy using your iPhone.
I purchased on December 15th bro 2024
Bro my iphone 15 plus stille while charging heating give me any suggestions bro
Hi bro Intha issue enakum irunthu I am using 14 plus after ios 17.4 update Aprom robin Anna video patha aprom backround apps off pannidu then reset all settings panne issue solve aiduchu
hi bro, as I mentioned in recent episode, during fast charging heating is normal. but current summer season is the main reason where the heat stays and takes time to reduce. room temperature increase agirukunga. so all electronic appliances during fast charging or power connected will see temperature increase.
it will auto cool down. dont worry. just avoid using phone while charging bro. that will help.
