iOS 17 to iOS 15 Downgrade Possible?
I’m currently in ios17, I’m facing lot of issues. Is it possible to downgrade from ios17 to ios15?
Hi bro, what type of issues you are experiencing? iPhone model and current battery health percentage?
Also its not possible to downgrade to iOS 15 right now as apple stopped signing iOS 16 and earlier versions. Even within iOS 17, you can downgrade only to last released version after its released for a week or two time.
But many users are finding it stable overall with latest iOS 17.2.1 version updates. Let me know above info and we can try some troubleshooting steps to try and see if any improvement happens.
Hi bro, I’m using Iphone 13 and the battery health is 87%. My mobile is 1year 3months old. I’m facing more issues like overheating while using camera, apps using more storages than expected, battery drain and etc.,
Do you have any idea about 3utools to downgrade the ios?
hi bro, in this case my suggestion is to take backup of your data in iTunes and then perform full iOS Restore. Then restore the backup and see how the overheating and other performance issues are.
So far latest 17.2.1 providing stable experience. So give it a try and use it for 4 to 5 days and let me know.
Do we have any video for this process in our channel?
There is a video for iOS Restore bro
But not for backup I think, you can take backup in iTunes if you are using windows computer first and avoid selecting Encrypt Backup option. If by default it encrypts then you may keep it that way.
Once backup completed then perform iOS Restore downloading the file from ipsw . me website.
