iOS 18.1 Battery Drain Home and Lockscreen Usage
Ios 18.1 le irukre 15 pro maxx le home andd lockscreen screen battery drain ahuthu Software 18.2 le fix ahuma
hi bro, already issue irukarathaala 18.2 update pannitu check pannurathu recommend nga. home and lock screen la widgets ethavathu use pannureengala?
No bro , Ios 18.2 update aale vere issues veruma bro about battery and heating
Reset all settings panniyum issue veruhuthu bro
No bro
So far no such issues reported bro. works normally on most devices. suppose problem vanthuchuna namma recent video la sollirukara mathiri all settings reset pannuna fix aagumnga. dont worry. update and check bro.
Thanks bro
