iOS 18.1 update Battery Draining Fast
After 18.1 update the reduce interruption option was not available on iPhone 13 bro and the battery also draining too fast bro. In photos section the background eraser option not available. I’m facing the after ios 18 update in the battery section showing slow charger issue still not fixed bro .
hi bro, as its new major update give atleast 3 to 4 days time as background process runs to optimise the device according to your usage.
Then share battery page last 24 hours screenshot on 4th day. with apps section visible that will help to understand whether any battery draining issue happens or not.
The reduce interruptions option is unavailable even in 13 mini. Updated to 18.1
After ios 18.1 update the clean tool option was not available bro
Cleanup tool is available on iPhone 15 Pro and above models bro.
some users are experiencing the issue bro. so waiting for an update from apple side to see some fix bro.
