Hi bro. Since after recent update my battery life jumped from 92 to 90%. Battery drains faster than usual and found over heating. I’ve got notified about battery usage. Pls do help me. I’ll attach SC below
hi bro, 90% is still good battery health. based on when the device purchased calculate battery health as said in our battery health reduce video.
As you can see from the above page, the notification says your recent usage have increased than usual. so battery consumption must have change according to that. its just a notification, not a problem.
When your usage pattern changes you will notice battery drain reducing again.
continue following the charging practice and it will be maintained bro.
about overheating issue, are you noticing it with normal usage or while charging the device?
Over heating problem are while on charge and sometimes during usage brother. I purchased my 15 pro max on nov 2023. Only after this 18.2.1 update im facing drastic changes in battery. Battery holds charge for a day but now I charge once in a day. In fact I use only WhatsApp in this device.
Hi bro, do share last 24 hours of battery page screenshot with apps section visible. scroll down little bit on battery page to show battery green graph, activity and top 3 or 4 apps. also tap on the app name to show background usage percentage too. then take screenshot and share it here bro.
Hello brother. I have attached the Screenshot below. Within a month battery health dropped 3% brother. Now it’s 89%.
Battery idle time reduce and usage time reduce all looks stable bro. as said earlier, battery health will reduce according to usage and automatically adjusts each month. sometime we see sudden reduce if there is any pending refresh to happen. dont worry. just follow the suggested charging practice and that will be enough.
