Hi Bro , after updating to Ios18.4 Public Beta version , i have issue with my Keyboard, im using swiftkeyboard as my keyboard but after updating 18.4 , while using keyboard is automatically changes to default keyboard , i do all the things and fixes so kindly solve this issue bro , you have any idea regarding this ?
Hello bro, possibly swift keyboard havent released any compatible update for iOS 18.5 beta version. so we have to wait for an update from the app developer side to see the issue getting fixed bro. Can you also test once with any other third party keyboard that receives proper updates?
Also as a basic troubleshooting step you can try reinstalling the keyboard app and try performing all settings reset. that could help if its iOS specific bug causing that issue.
Else as i said earlier, we have to wait for an update from developer side to fix it.
