Hi bro . I’m using 15 pro max and my family member is using iPhone 13 . In 15 pro max the size of ios 18 file is nearly 7 GB but in 13 it is almost the half of 15 pro max . Why bro ?
hi bro, after download, extract the system software size will reduce its size. after clearing the installation files. based on which iOS version we are in and iPhone model the size will be different. as Apple intelligence like feature not available on older models we see such difference in size bro.
