I’m using 17pro max after update iOS 27 when phone is locked incoming call answer slide button disappear always answer end button appear. What I do?
this could possibly be a bug bro. expecting fixes in upcoming updates only. for now restart iPhone once and use it bro.
Now I updated 27.2 but problem still not solved
Apple might have changed the way it was working with latest iOS 27 bro. i havent seen slide to answer button recently too. will check whether apple removed it or not, but high chances they made some changes recently. showing answer decline button all the time.
