I’m own I iPad 3 rd gen hardware problem in camera
Availability of replacement where & cost pl intimate
Regards Ari
Regards Ari
at apple service center they replace entire iPad mostly bro. if you prefer third party option check with iDot Repairs or iPick Service Center in chennai. they will check for any repair possibility and inform you.
kindly mention your current city if you need some suggestion other than chennai.
Good
Day! Bro I specifically requested whether it’s available in market because my friend says it’s vintage & end of life so just leave it if u can refer some shops from Tambaram or around Chennai
Thanks Regards Ari
Good day bro. going for vintage model is not a good idea bro. I personally dont have any contacts with shops. but do check with iPick Service center bro. they have shops in several places of chennai and have good reviews among our audience too. you can visit their shop in person and see used iPad models hands on to decide which one will be worth for the pricing. go for bit latest models to use the device for next several years without issues. it shouldnt be too old.
