iPad 5th Gen and iPad m2 air
Dear Robin Anna,
Ipad buy panna poren second hand 70k ipad pro 5gen m1 256gb model pathu iruken replacement unit sonnaru ennaku enna doubt m1 pro model best ah and air m2 model pakkalama evaru sollura price ok va bro 2025 la ipad pro m1 worth ah na ipad use pannathu illa new buy kojam sollugka bro…
Hi bro, new m1 iPad Pro or used? battery is important so used pakureenga na 1 or 2 years used with good price appadina paakalaamnga. otherwise new iPad Air M2 processor model oda compare pannunga. iPad Pro models la 120Hz display irukunga. thats an advantage. but price is important. so nalla condition and less used appadina iPad Pro M1 paarunga.
Otherwise new iPad Air M2 will be good buy bro.
New unit tha replacement unit display damage airuchu nu solle new unit vagki irukaru atha tha sale panraru 70k solluragka bro
I understand bro. but price wise 70K seems expensive option to go with. as a seller is is reasonable. but as a buyer when you go with M1 iPad Pro right now, getting it around 50K range will be good buy.
Have you seen iPad Air at stores recently? do you think the ProMotion Display or any specific pro features is important for your every day usage?
Ennoda usage office use next gaming edit some times bro maximum Office use tha enaku ipad experience panum asai bro atha confused ah iruku air choose pannalam thonuthu negka sollurathu patha ila 10gen kami price vagkikalam nu oru idea
10th gen can handle too bro. but display fully laminated and anti reflective coating kaaga budget wise ok appadina air consider pannunga. 55K budget la mudinjidumnga.
Ok bro👍
