Hy broo
Oru doubt broo can we use 2 in 1 adapter as like charging and headset for 9th generation ipad, apadi use pana audio out varum ha bro can u check and tell me bro
Hy broo
Hello bro, iPhone or iPad with Lightning supported Splitter or Adapters available. But not majority of them are MFi certified. If they are non MFi certified then we could see it stop working after few times of usage. Power drawing should not be higher than what the device is set. like 5W or below supported.
I can see this product has decent review on amazon, but we still have to buy at our own risk.
Also, its supported with USB C headphone and charging at same time. another branded one is from Belkin.
for 3.5mm audio headphone support. All of them are pricey bro. so decide according to the needs.
Now a days most of us moved to bluetooth headphones, so see if there is any alternative adjustment you can do, consider the pricing. if budget isnt a problem, belkin should be good choice to pick up.
Thank you for the update my broo… will check and will do that luv u bro
