@iRobinPro bro enoda ipad 12w adapater work agala bro enkita lightening cable original eruku. enala new one spend pani vanga mudla so na vera brand adapter use panalama like samsung oneplus?
with USB A to Lightning cable original adapter so far issue illama work agirukunga. You may use samsung adapter and see how charging works. if all is well continue using it bro. suppose charging problem iruntha future la apple adapter consider pannunga.
I am using this type of adapter with my iPad Pro and so far works well. But its USB C to Lightning cable. not USB A to Lightning cable bro.
are you using [Portronics Adapto 45 20W?
mine is 20W bro.
