iPad m4 pro case and protector
Bro yesterday i bought an ipad m4 pro 11inch… Now i need suggestion for screen protector and case… i saw your video on a matte screen protector … i know matte is good for gaming but will the clarity will reduce in game and in other media streaming apps because i will play pubg a lot and also watch movies etc… so will this matte temper will suit for both playing games and watching movies ??.. I also think folio cases will not suit for me bcoz when i need to play, i need to remove the folio case… so folio cases will not suit for me …Bro suggest me a good back case also… Viewers also suggest what do you use with your ipad pro m4 11 inch ???
Hi bro, matte is not good for gaming actually. glossy is the one that goes well for gaming. For average gaming its ok, but if you are planning for something frequent gaming, then consider glossy type.
as you play pubg a lot, then glossy it is. check with proelite series as not many alternative options available at present.
You may check iPad Skin options too bro. to avoid adding more weight and if you handle ipad carefully and wont be taking it to more places, then applying skins will be good idea. just to protect the back side from any possible scratches while places on desk.
Preparing one more video bro. just got my iPad pro M4 too. I use it for few apps to read, watch less videos and sometime games with friends. BGMI ofcourse.
Ok Thank you bro … Waiting for more ipad pro videos…
