iPad Pro 10.5 Smart Keyboard disconnecting problem
My iPad 10.5 pro, couldn’t supported Smart Keyboard some times.
Please let me know that how to fix.
Regards.
Do check the pin connector on the back of the iPad Pro and Smart keyboard. gently clean it with a cloth and try pairing it again bro. mostly it could be dust related issue and this will help fixing it.
Otherwise it could be pin damage issue or connector issue. which we need to check once with nearest apple service center. replacement of the smart keyboard may be needed based on product condition and ageing.
Now I am using iPad Pro 10.5” since 2017. Kindly let me suggest the best model for upgrade.
from 2017 model if you can find m2 ipad pro model its an upgrade too bro. otherwise latest m4 iPad pro can be considered. there is a good price difference between m2 iPad pro and m4 ipad pro. so have to decide based on budget here.
