iPad Pro m4 or m5? Which is Best Buy?
Shall I buy the iPad Pro m4 “13”inch 266gb wifi only non activated bought 5 months ago with apple care plus till may 2027 for 95k or should I go for iPad Pro m5 “11”256gb wifi only for 89000 with students offer.which should I prefer?
Checked its unactivated
hi bro, for m4 13 inch model price wise its good only. make sure to buy from trusted shop or seller its a good deal and use the device for few minutes before making final decision. iPad Pro 11” is perfect size for most users bro. as both are expensive options my suggestion is to personally use them once at showroom. see which screen size fits for your usage type. 13” is bigger and not suitable for casual holding and usage. media content will look stunning in that big display, but again how you are planning to use it matters.
so try hands on and then make the final decision bro.
