iPad Pro or iPad Air? Which is Best Buy for Business Usage?
Hi bro
First time Ipad vangalanu irukan bro for business use ku.
With cellular illa without cellular vanagrathu best…?
Also
Palaiya modal 12.9inch ipad pro best ha…?
Illa ipa vanthurukua ipad air 13 inch best ha…?
Performance vices yethu best nu solunga
:heart::sunglasses:
hello bro, for office documents, files management and apps usage iPad Air is sufficient bro. consider Pro model only if you need that OLED display for any photo, video editing color correction purposes and budget isnt a problem.
Cellular model is suitable if you want to put separate sim card to use internet while roaming. if you like to use hotspot from iPhone then you may go with wifi model. or in most places you stay has wifi connection, then wifi model is sufficient. else cellular can be considered.
12.9 inch model with mini LED Display also best buy right now bro. performance difference heavy tasks la mattum thaan notice panna mudiyumnga. for office purposes you wont see big difference.
Budget wise if you can find 12.9 inch with good deals and discounts then consider it.
Thanks Broo :sunglasses:
Also
Ipa 13inch ipad pro lunch pana nala
Ipad 12.9 oda price konjam drop panuvanga la bro
Bcoz stock clear pana thana bro papanga
En solran na kuwait :kuwait:( 320KWD ) la 86856 tha varuthu without tax 12.9 ipad pro oda price
Ipatha new model lunch panirukanagleey
Apa better inum price kamithana agum namma anga buy panum pothu apa namaku athu benefit thana bro
Yes bro. 3 to 4 months aagumnga. irukara stocks sellers valiya sell pannuvaanga. online and offline shops. trusted shops pathu vaangalaamnga. 12.9 is good model to consider bro.
