iPad Pro WiFi or Cellular? Which is Best Buy?
Bro ipad pro la wifi vangalam ah illa cellular vangalam ah ethu life long best ah irukum
hi bro, iPad la cellular model only for data purpose thaan use aagumnga. whatsapp sim service access panna mudiyathu. so data purpose ku mattum venumna separate sim activate pannitu iPad on the go la use pannalaamnga.
neenga irukara edathula wifi irukum appadina iPad wifi model sufficient a irukumnga. extra 10K budget cellular model ku neenga use panna pora method poruthu decide pannunga.
Not clarified bro
Normal la iPad lifetime 5 to 6 years bro. so WiFi model neenga travel pannumbothu phone hotspot use pannikalaamna choose pannunga. iPad ku separate cellular data service thevaipadumna Cellular model choose pannunga.
Bro, simple it depends on your use case. iPad veetla and clg or office la use panna poringa na wifi model enough. But portable ah carry pannitu povingana like in train, bus or flight go for cellular model. But as Robin bro mentioned you can always use mobile hotspot and save money by choosing wifi model. And wifi vs cellular models ku battery usage differ aaguma nu therila, Robin bro can answer to this.
There will be difference bro. cellular model normally consumes bit extra power for network signal search. but if the coverage is good and based on apps we use the battery performance difference will be there.
Thanks for the explanation bro🀝🏻
