I am using iPad 10th gen for about 3-4 months, I am having a issue in system storage. Mainly it is occupying nearly 9-10 GB, at a minimum rate of 8GB.
For this issue is there is any solution?
Hi bro, System storage is automatically managed based on our apps usage. it reduces and increases as we use. But if it keeps on going higher and like 20GB or more, then its a problem. We should perform iPadOS restore and see if that helps fixing it or not.
Make sure you have updated to latest iPadOS version. That will help fix any other bugs related to it causing spike in system storage increase on iPad.
Kindly wait, expecting iPadOS 17.1 to drop anytime soon. Then you will notice some more optimisation and difference in overall storage management as well.
