Hi
Iam using iphone 11 as my primary phone for the last 1.5 years and currently the battery health is 83%.
Would you suggest me to change the battery or should I continue, if You suggest me to continue until what % of battery health can i continue?
Whenever the battery change is needed, it’ll be shown in the battery settings itself, that’ll happen only when your battery health goes below 80%. Refer the image below.
So no need to change the battery now until unless you see any degrade in the performance or sudden reboots.
More info about the battery: iPhone Battery and Performance
Thanks for the clarification. This really helps
