iPhone 11 Pro Max Battery Health Fast Drop
Sir I brought a iPhone 11 Pro Max they said 100 bh i check in battery Heath is showed 100 only but after 1 month it gone 97 and in 1.5 months after 95 I used only less no even gaming u use YouTube and Apple Music no gaming u check my battery Heath with a shortcut it show
Your iPhone battery’s real stats:
MaximumFCC (original maximum capacity): 4114 mAh
NominalChargeCapacity (current maximum capacity): 3261 mAh
CycleCount (number of complete charge cycles): 1101 cycles
Relative to when it was new, your battery capacity is 79.27%.
hi bro, I think the iPhone 11 Pro Max battery must have replaced outside apple service center which could be non genuine battery component. that is why it suddenly drops in short period of time. If its few months usage and suddent 2 or 3% reduce, then its normal. otherwise battery is not able to deliver the performance as it intended too.
if its new battery then the capacity shouldnt be shown as 79%.
Did you get this phone recently? bought it from any shop or seller?
