Hi bro,
When, I am attended any calls the speaker was automatically turned on. Once the speaker turn on the live calls it’s automatically disconnected. Please give me a solution… If you have any idea for that.
Note:
- I am facing this issue last 3months. I tried to update iOS software every month. But still that issue not resolved.
- I reached apple customers care for this issue in multiple times. They said developer working on this (same answer they said every time)
hello bro, do check settings - accessibility - touch - call audio routing set to automatic. also Auto-answer calls should be OFF. Both settings correctly set or first one set to speaker?
Hi bro , it’s a default settings in my mobile what you suggested even though still I’m facing the issues
This problem was there in older iOS version bro. but now I am not seeing it or reported. Do perform settings - general - reset - reset all settings" once. If you havent done already. Else no need to repeat now.
Then see how it works bro.
Okay… bro will try and let you know
Thank you so much bro… now I’m not facing that issue.
Glad to know its fixed. have a good day bro.
