Hi, can i upgrade my iPhone 11 storage 64gb to 256gb using third party service centre??. Is it recommendable.
you have to visit any service center that doing chip level service bro. if you are around chennai, check with iPick service center, and if you are around Coimbatore then check with iPlace. We have to do it at our own risk bro.
I checked with Ipick service center chennai. They said they have stopped upgrading storage because it’s causing issue for some users. Thanks for suggesting to check with Ipick service center.
Good they mentioned it before doing the work bro.
