iPhone 12 battery replaced and poor battery backup
I have recently replaced a orginal apple battery in 3rd party service center. My iphone 12 is not even standing for 5hrs. If screen on time is 3 hrs and above already my phone is 20 percentage
Usually how long does iphone 12 survive in 26.3 update with 97% battery health. Should i change the battery ?
hi bro, I havent tested it iOS 26.3 with iPhone 12 yet personally. but if the usage like instagram, facebook, youtube videos then its normal to see such fast reduce. otherwise even for normal usage or standby if the battery not lasting for more than 5 hours then its not good.
if it shows battery health correctly, then its possible due to iOS 26 and its liquid glass animations we may see such reduced battery backup.
now a days with 5G and signal coverage not being strong in many areas, we do see such battery drain issues.
Only if battery health not showing or other fast drop in percentage like while using you are visibly seeing percentage drop continuously then its a battery specific issue. you can check with same service center. otherwise if it reduces gradually, shouldnt be battery problem bro.
