iPhone 12 in 2025 worth buying?
Hi bro iPhone 12 in 2025 okay per day my mobile usage only 5 hours
Hello bro, for average battery performance 12 model is still good buy in 2025. suitable mostly if you can carry powerbank or any power source available in case of heavy usage requirement in some days. if the screen on time increases, then we need to charge around 3 or 4 PM if you started with 80 or 100% in the morning.
It depends on network signal strength, display brightness and type of content we consume. like instagram, facebook apps does consume more power than regular usage conditions.
Plus or max models are considered for good battery backup options bro.
iPhone 12 users are able to get through one day battery backup in 2025 with normal usage.
