iPhone 12 interface by hackers
Hi,
I have big issue as some people keep hacking my devices I lost some devices because of them as they are using hidden apps and they always modifying as entering inside accessibility then voice command then buster then some lines I can’t make any change some I can but after few time I found them return it back today I found at screen time - activity
CTnotifyUIservice
UserAuthentication which I dnt see it at my mobile I tried many times to reset my network and screen layout and privacy & locations still they are installed hidden network I found at my WiFi as managed network I NEED HELP
Hi bro, CTNotifyUIService is related to Cellular Network usage, authentication and error purposes. Don’t worry. its not the way hackers use to hack your device. You can make sure iOS is updated to latest version so such hacking attempts can be prevented.
about the getvpnproxy . com is there any VPN app you are using?
