iPhone 12 Pro Green Lines on Display
IMG_4167
Hi bro I am using iPhone 12 Pro after updating iOS 17 the green line is visible in 4 sides of display while watching social media what should I do now ?
Hi bro, do you see those green lines during video playback or while using the phone normally? do test it by opening white image and see if green lines appears or not.
Green light is blinking while using media like YouTube,insta and facebook and while seeing the photo in in gallery in night time I am able to see the green line is blinking
During video playback bro the green link is blink in 4 sides
This could be display hardware related issue too bro. if its software specific issue then we will see such issuse in just one or two apps. and performing “Settings - general - reset - reset all settings” will fix the problem.
Otherwise we need to check once with apple service center to know exact issue and service options bro.
I tried to reset all settings in few months ago but still the green line is visible
And my iPhone is out of warranty
What shall I do now bro
Apple will replace my screen or not ?
Sad to know bro. this could be hardware specific issue in this case. like too much pressure applied on the display when we keep it in pocket or carrying some heavy weight objects. without our knowledge it might have happened.
At apple service center they will tell us what the problem is. but they wont replace it for free. display replacement cost is quite high too.
Comes around 25,500 for display alone. Which is not a good idea to spend on 12 Pro model in 2024. If there is any exchange offer comes in third party mobile shops or websites like cashify you may consider in future to sell it bro.
If the lines rarely appearing are not bothering much, continue using it bro. dont sell it right away.
then you can upgrade to a different model.
Another alternative is, checking with third party service center to change display bro. we may not get same original display unit, but that is another option we have to try at our own choice. Price of display could be half the cost of what costs in apple service center.
Bro otherwise shall I reset my iPhone
For display hardware related problem, resetting settings or iOS Restore wont help bro. We need to check with service center.
