iPhone 12 Pro Max Battery Change suggestion
Bro I have iPhone 12 Pro Max I need to change battery in iplanet if I change battery in authorised service centre the data will be remover or it will be safe
Hi bro, for battery change data wont be erased. If there is a need for backup, service center always guides you on that. just ask them once too. they normally deliver the phone after battery replacement in one day time. so kindly check with them.
