iPhone 12 pro max to iPhone 13 upgrade
Iphone 12 pro max la iruntu iphone 13 upgrade pannalama or 12 pro max better ah nu sollunka :confused:
iPhone 12 Pro Max is better than 13 model bro. you could wait for 15 release if you can use the phone without any issues. that will be good upgrade to consider. If you are upgrading to iPhone 15 Pro or Pro max.
Thank you bro
But 12 pro max modal la brightness 10% ku kela vareka settings page la menus la green shade varutu itu normal ah enoda friends mobile kum same problem iruku
low power mode la brightness low agirukumnga and as its OLED Display, you may see such color change. make sure you dont have settings - accessibility - display & text size - color filters ON. If its ON turn it OFF.
around 20% varumbothu charge pannunga. it will be good to maintain battery health.
Thanks for your information bro 2021 march buy pannan primary device ah use panran gaming photography elame itan still 86% battery helth
Thats good bro. keep following the charging practice to maintain it well.
