iPhone 12 Pro or iPhone 13 Used? Need Suggestion
Hi bro I have a query can u please help me with this ,
I am planning to buy an apple iphone but I have a slight confusion in buying an iPhone 12 pro with iPhone 13 in a second hand market ,and can we put apple care+ for this product now !..
hello bro, applecare+ can be applied only within 60 days from the data of purchase of the device bro. not possible after that. So used models normally either crossed that days limit or the warranty ended.
If you are buying new iPhone 13 then yes bro, you can put applecare+ by calling apple support or by visiting nearest apple service center.
Iam going to buy a phone in a second hand market nd they are giving me iPhone 12 pro and iPhone 13 almost at the same pricing around 38k . Iam in a confused state Can u please suggest me a phone from this two ! …
Both are 60Hz Display but Pro model is bit better in this case. Consider iPhone 12 Pro model bro.
Thank you so much bro in tamil YouTube community I basically believe only you about the apple products …
Will keep doing my best bro. :pray:t2::heart: You can search our forum or channel to find some answers faster too. else create a new topic here and will answer at my available timings. good night. sleep well.
